How Do You Have Your Fuel Lines???
I just ran them along the brake lines where the stock fuel lines were. I have seen cars that took them inside the frame and brought them out up front. I with I would have looked closer to see how it was done.
Heres mine being feed on the passanger side threw a filter and i mounted the fuel reg on the drivers side which returns from there threw that protective metal thin plate mounted down low near the steering shaft that hides the brake lines and stuff and keeps the return line away from the exhaust! I looked a 100s of setups before i picked this way!Its the cleanest and simplest
http://s243.photobucket.com/albums/f...erhood%20pics/
Here are a few of mine, The A1000 mounted in the frame rail
From underneath
With the tank.
The filter and stuff
Here I put it where the factory put the LT1 lines under the driver side.
Came up the inner fender and drilled 2 holes, supply and return
Then into the engine compartment.
From underneath
With the tank.
ok, thanx. ya i tried looking up that tank and couldnt find it. i will just contact them like u said and see what they say
Mine is mostly aluminum. There are just some places you have to have braided.
11Second Club
I ran my return along the stock feed line. There were a couple points where I deviated a few inches to avoid proximity with the exhaust, but for the most part I followed it the whole way. Towards the front, I tucked it under all the heat shielding for the stock feed line that I could manage to stuff it under. It turned out pretty good, I think.
