injector size
Old 04-20-2009, 11:41 PM
turbochkn's Avatar
Default injector size
i have a 2000 ta w a 6.0 going in and a 72mm front mount borg warner turbo just wondering what size injectors you guys w big turbos r running thx.
Old 04-21-2009, 02:25 AM
black98ws6ta's Avatar
Would ultimately depend on what power level you wanted to support, but it sounds like 60 lbers should match the turbo fairly well.
Old 04-21-2009, 08:28 PM
turbochkn's Avatar
Default hp#s
what power would a 60lb injector be able to support safely .iwant to make somwhere in the 800 range
Old 04-22-2009, 02:23 PM
Ouija's Avatar
I know for a NA application 8 - 60lb injectors would be safe up to 768hp, so that seems a little small to me for a FI setup, but I could be wrong.
I'm basing my calculations off research I did 2 years ago, so someone else might be able to chime in...
https://ls1tech.com/forums/fueling-i...ctor-size.html
Old 04-22-2009, 03:02 PM
salemetro's Avatar
I just bought a set of 60lb Siemens Dekas...they are rated at 60lb at 43 psi. If you run them at 58 (stock ls1 pressure), they will flow closer to 72lbs. Something to consider.
Old 04-22-2009, 04:46 PM
FICINJECTORS's Avatar
800 wheel or crank? If wheel auto or manual?
Old 04-24-2009, 12:27 PM
turbochkn's Avatar
800rwhp currently stick but thinkin about automatic
Old 01-30-2012, 02:53 PM
JoshuaGrooms83's Avatar
@salemetro
is that for real? 60lbs will flow like 72? cuase if tht the case. what would 72s flow like lol cause i might be getting some for real cheap and im only shooting for 500hp at the wheels lol
Old 01-31-2012, 11:23 AM
ZL1Killa's Avatar
You will need pumps to support this and a FPR so that your equivalent seen fuel pressure at the injector ramps up with the added boost.
I would say 80# rated at 43.5psi
my reasoning behind that is I'm running 79# and ran a 71% duty cycle making 650 & 680 at 11.5 AFR
Old 01-31-2012, 01:48 PM
huh, so if i have a racetronics pump with wiring harness with 60# injectors and maybe some billet fuel rails for "flare" lol shold be a good foundation for 500rwhp (and a good tune of course lol) gona be using a T72 or T76 with a .84 AR
Old 01-31-2012, 03:13 PM
ZL1Killa's Avatar
here is the kicker... the 255 pump maxes out at 51.3LB/hr ...
https://ls1tech.com/forums/2638447-post1.html
You will be able to make 500rwhp with your mentioned setup. If you push beyond that, you will need a larger pump or second pump. And make sure you have a FPR.
Old 01-31-2012, 04:30 PM
huh, thats not cool lol ok, so keep it at 500 (like i pretty much what i want... for now lol)
ok.... sooooo twin in tanks huh. guess ill be enjoying racetronic for a short amount of time lol
Old 02-01-2012, 11:30 AM
ZL1Killa's Avatar
sorry if I forgot to mention that in all the PMs we had. Fuel pumps and injectors are about the same with regards to flow and realizing there maximums
Old 02-01-2012, 03:39 PM
yep i remember. from what ive been reading around and keeping my boost and and hp number to 500ish 60# injectors and a new Racetronic pump will keep me pretty safe with a good tune of course. Im not looking for 800 or something crazy. yet lol
Old 02-02-2012, 08:25 AM
ZL1Killa's Avatar
yeh you will be fine. Me on the other hand...I'm going to have to dial it back to keep from making 750 and having to upgrade injectors.... this 6.0L and boost absolutely love each other
Old 02-02-2012, 09:54 AM
one day ill try that lol
