h/c ss falls on face on dyno-fuel issue
I took my h/c car to get dyno tuned , but had some issues. When it hit the dyno the tuner said that it had low fuel pressure. He said it had 22 lbs which i checked when i got home and confirmed to be true. 22 lbs at startup , and less throughout the rpms. He said that it could be the small fuel line going to my freshly installed walbro and 42 lb injectors. He gave me a part number for a gates submersible line #27093. What do u guys think, Would this line cause the pressure to be so low? He said it should be about 58 or so. The car still dynoed a 415rwhp and 397 ft lbs but fell on its face at 5000. Is this the issue or do u guys think its something else?
well if you had only 22lbs, my guess is that when you get the right fuel pressure your car isn't going to run too well. Some guys have had issues with their brand new walbro. My guess is that you have a problem with the fuel pressure regulator or pump. I'm not really sure what line you are talking about though.
Knew that the FP was fubar, and dyno'd it anyway??
I'd be finding a new tuner! Either that fp reading is wrong, or you are very lucky.
NO WAY did that engine make nearly 500FWHP w/ the fuel injectors operating at a flow rate of 25.8#/hr.
And, this makes it even scarier: "and less throughout the rpms".
Yea , as you can see in my post that i asked if anybody thought they knew what was wrong with my fuel pressure. If you dont have a clue , just say so. No need to insult me , or possibly the best tuner in the ny nj area Matt from ttp by calling us liars. I'm not some child that needs to lie about what his car did on the dyno.I have a dyno graph a whiteness, and matt as proof. Also , the car was dynoed before the fp issue was found, when he realized that the car was not at full potential he checked the fp and stopped the runs. Do you want a video of a fuel pressure gage on the car? The fuel pressure was checked several times on two different gages, so i doubt its wrong.
Yea , but im one of those that just hates to cut up the car, but maybe it would be a good idea. I do have a hotwire kit, but have not checked the voltage yet. Do you think it might be the issue?
