High HP fueling Q
Old 09-29-2009, 08:51 PM
wilson34's Avatar
Default High HP fueling Q
Have a question guys, I have a corvette eventually going to be running some pretty high hp and am wanting to go with a magnafuel efi pump.
Since I can not sump my stock tank would it be possible to run the stock pump from tank to a custom external tank up front with a magnafuel pump running off of that?
Wouldn't this insure the pump always has fuel if i go with say a 2gal fuel cell.
Thanks!
Old 09-29-2009, 08:57 PM
wilson34's Avatar
You know what, the more I think about it I have seen others tap the stock vette fuel tank..
What would be the safest way of running the system? Stock pump fueling 1or2gallon cell to magnafuel, or magnafuel directly off of stock tank?
Old 09-29-2009, 09:08 PM
wilson34's Avatar
Sorry I keep adding questions, but
Would I want to run the return from the Magnafuel back to the surge or to the main tank?
Or would I need to run 2 regs, 1 from magnafuel and 1 from stock pump before the surge tank?
Old 09-29-2009, 09:57 PM
STAR's Avatar
Here's a surge system:
http://www.lgmotorsports.com/catalog...oducts_id=1971
Here's one you tap into the factory tank:
http://www.dallasperformance.com/DPC6fuel/index.htm
Old 09-29-2009, 11:52 PM
wilson34's Avatar
I know of those systems, but I can easily replicate for cheaper, I'm wondering as to which type is better.
Old 09-30-2009, 08:49 AM
wilson34's Avatar
Ii meant for cheaper. I'm wondering if these systems are good for occasional street use, like being able to drive for an hour.
Old 09-30-2009, 09:01 AM
allngn_c5's Avatar
The Dallas Performance setup claims safe enough to daily drive and / or take on trips.
Old 09-30-2009, 09:18 AM
edcmat-l1's Avatar
Call up Racing solutions.
http://www.racingsolutions.com
Old 09-30-2009, 12:03 PM
Nasty N8's Avatar
How much power are you planning to make?? We have several much simpler systems for big power.
Old 09-30-2009, 05:41 PM
wilson34's Avatar
Over 1000 to the wheels and occasional e85 use, I'm looking to make a DIY system instead of purchasing an expensive intank setup. The magnafuel is a much better choice for me based on budget.
Old 09-30-2009, 05:43 PM
wilson34's Avatar
Wow, just looked at your prices and didn't realize your double pumpers were priced so well, good job Nate!
I may need 3 pumps though to fulfill my need as I'm going to go over 1000 at times.
Old 09-30-2009, 06:46 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I can design a triple intank system if you need that much, but my dual pump setups will support over 1000rwhp on gasoline. I assume this is for the C6 shown in your signature?
Let me know if interested in a reliable intank setup.
Old 09-30-2009, 06:52 PM
wilson34's Avatar
Nope going in the C5, hopefully a twin 70mm system soon. I don't know if I could justify spending money on a triple when I could have an external setup for 1/3 the cost typically.
Nate, How much do you think your twin setup with an external bosch 044 would support?
Old 09-30-2009, 06:58 PM
LS1TECH Sponsor
The C5 is easier yet to build a triple for.
As for the pump kits that Nate sells, I build them.
The dual intanks plus an external 044 will support well over 1600rwhp on gasoline with the appropriate lines etc.
Old 09-30-2009, 07:54 PM
wilson34's Avatar
Can you hit me up with a price a setup with the c5 dual intank with a 044 pump with just the install kit + wiring and hobbs switch.
I don't need any of the hardware or lines.
ThaNks
Old 09-30-2009, 10:08 PM
LS1TECH Sponsor
Please give me a call at your convenience so that I can better understand your exact needs & price the correct installation kit..
