Racetronix or Walbro??
Old 10-20-2009, 01:13 PM
chase3's Avatar
Default Racetronix or Walbro??
Fixing to do sts on current setup..Cant decide whether to put the walbro in or buy the racetronix kit that comes with harness..THANKS FOR ADVICE Chase
Old 10-20-2009, 01:33 PM
tko0383's Avatar
I vote the racetronix. The racetronix is a modified walbro.
https://ls1tech.com/forums/fueling-i...same-pump.html
Old 10-22-2009, 11:34 PM
Goldfinger911's Avatar
I have read that they are different, however I have seen both pumps side by side and there is no visual difference except for the fancy aluminum cover and wiring kit that Racetronics includes. The pump I am comparing is a US made Walbro GSS341 part# 18105-3. I ran two of these in my Supra and never ran out of fuel to 600whp through an auto.
Old 10-23-2009, 12:35 AM
ramairws6's Avatar
They are both one in the same.............
Old 10-23-2009, 01:58 AM
uphigh07's Avatar
i would say walbro there the same but you can get the walbro cheaper, i have 2 cars with twin walbros, no problems at all
Old 10-24-2009, 08:53 AM
koolaid_kid's Avatar
Whichever you go with, I highly recommend getting the harness. It provides full voltage (and current) to the pump at times of high demand, which the factory harness cannot do with aftermarket pumps.
Old 10-24-2009, 10:05 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
The supporting equipment is what makes or breaks the install. Poor wiring & cheap intank hoses, plus the lack of the proper venturi setup are what causes most of the problems with pump installations in these cars.
Also there are a few version of the 340 series pumps & some are known to be troublesome.
I recommend the Racetronix as you often get what you pay for.
Old 10-24-2009, 08:24 PM
chase3's Avatar
yeah i went ahead and ordered the racetronix pump and the hot wire kit for it..thanks for all the responses guys!!!
