ford injectors
Old 12-16-2009, 12:22 PM
franksaltz28's Avatar
Default ford injectors
I have injectors 39lb injectors from an 03 cobra that i want to put on my 98 camaro. The injectors arent the same conection. Should i modify them, or should i sell them and get some new ones.
Old 12-16-2009, 01:55 PM
FICINJECTORS's Avatar
Originally Posted by franksaltz28
i have injectors 39lb injectors from an 03 cobra that i want to put on my 98 camaro. The injectors arent the same conection. Should i modify them, or should i sell them and get some new ones.
that injector has a split spray pattern as it was designed for a multi valve intake like the ford. They do not work well on single intake systems. We can trade those on ls1 injectors that will suit your needs without any plug modifications
Old 01-08-2010, 11:55 PM
pipefitter guy's Avatar
can you tell me if 39lb injectors out of a 03 cobra with ev6 plug will work on my 99 ls1 z28 camaro
Old 01-09-2010, 08:43 AM
those injectors are no good for a ls motor, as I said in the post above. They have a split wide spray nozzle that are designed for engines with 2 intake valves. Ideally you want the spray to hit the center of the intake port so that the fuel vaporizes off the hot intake valve. These injectors will wash off the intake ports and cause a poor mixture. Call me and get the right injectors with the right spray pattern and plug
Old 01-09-2010, 03:31 PM
Race your car!
JL ws-6's Avatar
The green top 42 lb injectors don't have the same problem do they?
Old 01-09-2010, 03:48 PM
no they are fine
Old 01-09-2010, 04:12 PM
transamsam98's Avatar
how much would we be looking at price wise cause thats the injector I'm running as well and have the adapters to
Old 01-09-2010, 09:27 PM
ls1 42's are 239 a set
Quick Reply: ford injectors
