Aluminum Fuel Lines Question
What would be the pros and cons of using aluminum fuel line compared to braided? Going to be doing twin intakes and use the stock feed line as a return. Thanks
I'm using seamless stainless steel for my lines. More rugged, harder to flare (have to buy the right tool to flare stainless) Plus knowing that you are better off using stainless vs. aluminum for rigidity and are less prone to break.
I have been running aluminum on mine for 5 years now with no issues plus a couple of other cars I built for others. Use the correct rubber isolator clamps to secure it to the vehicle and there should be no issue. I have braided line on the engine end to compensate for the engine movement.
