Will stock injectors work?
i believe they are either 26 or 28 depending, neither will change the high duty cycle you will be running with your setup with one you will be at 94%, the other at a little under 90% as a general rule you are to stay around 80%. If go 60# and be done with it, that should hold you over until you need to redo your fuel system(rails, return, dual pumps, etc)
