Car won't start, no fuel press. I really need help.
Long storry short,car would not start once I got to work the other night, no fuel pressure in the rails, cannot hear pump kick on. replaced fp relay,and fuse, they are getting power,towed car home today,put in garage, I took off the fuel pump harness, and put a multimeter on the big black and purple wire, I believe that's the power and ground for the pump. and there not getting any voltage, when I turn the key on or off. Even if the pump went out,wouldn't I be getting voltage to the wires? Isn't the purple and black wires the power and ground for the fuel pump? Im really at a loss and need any help. thanks.there are 4 smaller wires connected to the harness, they are getting around 5v. that's it. Would it be safe to run a jumper from the pos. battery to the purple wire and plug in, just to see if pump kicks on ?
I can't find anything about a safety cutoff switch to the fp if the car get's in a accident? If there was one, I would look and see if it kicked on.
Car is my 06' gto. thanks for any ideas.
Check your oil sneding unit behing your intake manifold, on GTO's (and may be other LS cars) if pcm can't see a good sending unit it won't allow the car to start. GTO's have been known to have a bad oil psi s/u.
Would the oil sending unit make the pcm cut power to the fp?
and I did have my son cycle the key, and no power to the purple wire. can I run a jumper from the battery pos. or fuse to the purple just to see if the pump kicks on?would that be safe enough to just try it out? I really appreciate the help....Lonnie
Okay, just ran a jumper wire to the purple and was getting 12.5v. and still nothing pump would not kick on. So I'll take the tank out tomorrow and I'll have to get a new pump. To bad I couldn't get a discount you didn't have a discount for us having the same first name Lonnie...lol thanks for the help guys, this was going to be my next mod, I just wished it would have made it until the spring.
i have a walbro gs340 for sale it has dyno time only, i will sell it to you for 70 shipped to you. Im in kansas so it wouldnt take long to get to you. pm me if your interested
Thanks for the offer, but I have to get the gto kit, with the spacers, or I heard it's a pain to get it to seal.
UPDATE: got the tank out today, pulled out the sending unit and pump, and here is the plug that goes into the fuel pump. Im hoping my new walbro kit will come with a new plug. this doesn't look too good...Lol
Okay guys here's an update, got tank out just now, here is the plug that goes into the fuel pump. Im ordering the walbro lingenfelter kit tomorrow I hope it comes with a new plug.
LS1TECH Sponsor
The GTO connection is an odd one. Not sure who sells them locally & I do not believe GM sells fuel sender parts. The new aftermarket pump does not come with that wire either.
I suggest you start looking on ebay for a used GTO buckket.
Does the connector that plugs into the sending unit have a green rubber seal around it? I have a 2002 Trans Am that's doing the same thing, felt behind the manifold and sure enough something behind there's not connected. I tried putting that one connector in there but it doesn't fit, can't really rotate it or see if I'm putting it in correctly
