has anyone ran these injectors? 103lbs? 80lbs?
Old 04-09-2010, 11:52 AM
4SFEDZ's Avatar
Default has anyone ran these injectors? 103lbs? 80lbs?
http://fuelinjectorconnection.com/sh...&productId=211
i would rather not go with a converter box and what not, and am still running a stock comp. is there any disadvantage with running high impedance as opposed to low? im looking for 750 or so at the wheels with the s475, but then im goin to send it to forcedinductions to bore is out to a 88mm, and only want to do the injectors once! so how much will the 80lbs make, i run 47psi fuel pressure so really the 103's will be more like 90lbs. this is a ltx car.
Old 04-09-2010, 12:38 PM
AFASTYZFR1's Avatar
I just put 80lb injectors in this camaro and plugged in like stock
https://ls1tech.com/forums/forced-in...c-build-5.html
Old 04-09-2010, 03:44 PM
stevieturbo's Avatar
They'll perform better than the commonly used low impedance ones.
Old 04-09-2010, 11:05 PM
4SFEDZ's Avatar
no ones ran the 103's?
Old 04-13-2010, 10:28 PM
4SFEDZ's Avatar
no 103's?
Old 04-18-2010, 11:36 AM
Casey2323's Avatar
Default well
I run 83's... They go a ways... I have a set I am looking to sell... I have never seen many guys with 103's??.. most they have new stuff out almost daily ....
Old 04-18-2010, 01:51 PM
ZL1Killa's Avatar
at only 47psi fuel rail pressure....you will want to bump that up, c'mon where is da power.
get you some 75+ LB/hr fuel injectors and a fuel pressure regulator setup w/reference to the manifold & you will be set.
get your fuel pressure up to 58psi, you could go with a smaller injector if you do so
Old 04-18-2010, 08:57 PM
4SFEDZ's Avatar
so u have 83's in ur truck now? are the high impedence or low?
Old 04-21-2010, 06:15 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
There's a Ford racing injector that flows something like 80 lbs / hr at 39psi.
I don't have time to read through the link, but here's the thread:
https://ls1tech.com/forums/fueling-i...injectors.html
Old 04-22-2010, 11:06 AM
Nasty N8's Avatar
The 80#ers are good for about 800-900rwhp depending on fuel system behind them and tune. Pump volume line volume and boost reference regulator make a big difference. Any higher than that to properly control the inj. you will want to step it to a high quality low imp. and a converter box.
