Mixing race gas with pump gas?
Old 08-31-2010, 06:17 PM
wrxrick's Avatar
Default Mixing race gas with pump gas?
I was wondering if I can safely mix 50/50 mix of unleaded sunoco 104 octane with shell vpower 93 unleaded "pump" octane? Will it still work out to give me 98 RON octane rating? Will this not mix well? Will it make my car run bad? It's a turbo car...and I just want a bit of added safety.
Thanks,
Rick
Old 09-01-2010, 07:12 AM
Old Geezer's Avatar
NP. Done it many times.
Old 09-01-2010, 09:34 AM
LS1DIME's Avatar
I run 50/50 mix VP 110 from our local marathon and 93 octane! Running Strong for almost 3k miles!
Old 09-04-2010, 10:42 PM
turningfast's Avatar
No problem. I mix 5 gals of sunoco blue with each tank of gas, for the last 10k miles at least. The blue is leaded though, and messes with the o2 sensors and wideband sensor a little. Unleaded will give you no problems. It may skew your fuel trims a little depending on the specific gravity of the fuel and if it is oxygenated or not, compaired to what it was tuned on. So you may need to tweek your tune a little to be optimum.
Quick Reply: Mixing race gas with pump gas?
