Should I step down my injectors?
My 1999 Camaro Z28 was originally rear mounted turbo but switching to a simpler cam/boltons and eventually nitrous setup.
I have a walbro pump, kenne bell boost-a-pump with a hot wire kit and 60 lbs injectors.
The planned setup:
FAST 78mm intake manifold (unported)
Throttle body to match
Lid/Filter/smooth bellows
TSP Tsunami Cam
241 Heads with springs
Pacesetter 1 3/4" primary long tubes
QTP manual cutouts (for now)
High flowcat 3" Y pipe
3" intermediate to a magnaflow catback
Will probably end up doing 100-125 wetshot with a plate
Will the 60lbs be bad/inefficient at the % they will be running at? I'm willing to step down.. but I don't know anyone interested in swapping for sayyyy 42lbs injectors. All insight is appreciated!
The planned setup:
TSP Tsunami Cam
you should be fine. you are running a wet shot instead of a dry... those injectors should work fine. you may have to do a little tuning on the injectors, but they should be fine.
The only concern i have is I won't be putting the nitrous on for a bit until i sell some of my turbo parts from my other car.
You think all motor Frost will be able to tune with those injectors? (Mail order tune)
I'd give your tuner a ring (or an email) and see what he thinks, as he is ultimately going to be the one making the tune.
I would imagine you shouldn't have any tuning issues running a quality 60# injector N/A.
When your turbo car is idling and cruising it's not in boost and the 60# injectors don't drown the engine, right?
Will do thanks!
