braided stainless fuel line?
Old 06-12-2011, 09:00 PM
hodge9386's Avatar
Default braided stainless fuel line?
well i been searching for a lil bit and havent found a clear answer yet, but i may have missed it, so im just gona ask.
what exatcly do i need to braided stainless fuel line from the quick connect on the drivers fender to a stock ls1 fuel rail.
i found a pic of this done on here, i forgot who it was
Old 06-13-2011, 04:37 PM
hodge9386's Avatar
anybody?
Old 06-14-2011, 09:03 PM
hodge9386's Avatar
seriously, is there anybody that can help me out here?
Old 06-14-2011, 09:19 PM
SirNemesis's Avatar
I'm not sure what size your factory lines are, or where you could get this locally, but if you get stuck these guys send worldwide.
http://www.ebay.com.au/itm/Quick-Con...item230ee3a00c
http://www.ebay.com.au/itm/Quick-Con...item230ee39ff2
Old 06-14-2011, 09:25 PM
hodge9386's Avatar
thanks man, i know i obviously need a adapter for the fuel rail, a 90* fitting and about 2 ft of braided stainless line, but i need to know what size i need and were to get the quick connect.
Old 06-14-2011, 10:09 PM
CNTLSE 1's Avatar
Contact speed inc. I dont remember the sizes but that is where I got all of mine from for their fuel rails
Old 06-18-2011, 02:27 AM
67RSCamaroVette's Avatar
Ok, buddy. You'll need
2' of -6 AN line
1ea -6AN 90* Hose end
1ea -6AN Straight Hose end
1ea Russell 640853 Specialty Adapter Fitting
Old 06-18-2011, 08:24 AM
hodge9386's Avatar
thanks man, thats exactly what i was needing. sweet car by the way.
Old 06-18-2011, 08:36 AM
Ollie8974's Avatar
Those Russell 64085 Specialty Adapter Fittings are available from the vendors who support these forums.
Old 06-18-2011, 08:44 AM
Kleeborp the Moderator™
MeentSS02's Avatar
You might take a second and read this thread before deciding on the Russell quick disconnect fittings:
https://ls1tech.com/forums/conversio...-fittings.html
Although the ones I've used in the past never blew off under pressure, they were very hard to tell when they were or were not secure on the hard line.
Old 06-18-2011, 06:21 PM
Wow, thanks, steve! Edelbrock sucks, and always has sucked.
Old 06-18-2011, 08:18 PM
MeentSS02's Avatar
No problem... if I hadn't had a bad experience with those fittings before, I wouldn't even mention it.
Old 06-19-2011, 11:25 AM
hodge9386's Avatar
2' of -6 AN line
i was lookin at the stock fuel line today and my fuel lines dont hook to the front of the fuel rails like this, it goes into the side like this
and hooks up to quick connect on finder like this
so is this still gona work?
Old 06-19-2011, 11:28 AM
hodge9386's Avatar
i think im gona have to buy another russell fitting and straight piece to make it work.
Old 06-19-2011, 03:36 PM
I assumed you were using it for aftermarket rails. A second fitting will make it plug into stock lines. I would use two, -6an straight hose ends, and eliminate the 90* I reccomended.
Old 06-19-2011, 04:06 PM
hodge9386's Avatar
yea its fine i already ordered what u suggested earlier, i should have looked at my car better before i ordered, ill just use it when i get aftermarket rails later. i ordered another straight and russell fitting to make it work with the stock rails. it didnt cost as much as i thought it would, about 75 bucks for everything shipped.
Old 06-20-2011, 08:13 PM
02blackbeauty19's Avatar
You guys can always pick up the metal retaining clips that insert inside the fittings to keep them from coming off.
Old 06-21-2011, 09:10 PM
realsquash's Avatar
I've never seen those, what car would they be found on? Or what part number would they be? I have the Russell fittings and I was concerned about the cheap plastic clips, too. I bought new ones (to replace the new ones that came with the Russell fittings) from Advance Auto and they are much sturdier, but still plastic.
Andy
Old 06-22-2011, 06:52 PM
hodge9386's Avatar
so is the other line that comes up next to the one that goes to the fuel rails the fuel pressure regulator line or return line or something like that? is it the same size as the other one cause i got enough braided line to both i would just have to buy more fittings.
Old 06-30-2011, 02:28 PM
HoLLo's Avatar
I'm workin on making a stainless braided line from the engine bay to the fuel rail, because I accidentally kinked the stock line when replacing the intake manifold with a painted one. It's going to be almost $80 for all the parts, I'm ordering this weekend, I will update the thread when it's complete.
Quick Reply: braided stainless fuel line?
