700whp on 255lph and 190lph ?
I was thinking of changing my feed line to a -8 and using -8 lines to join to the fuel rails together.
I make just over 600whp now but I start leaning out and have to shut it down 1100 rpm early.
LS1TECH Sponsor
It makes a huge difference how the pumps are wired... if you just spliced 2 pumps together in the tank on a stock wire, you have a problem.
You also need a better power feed to the pumps from the battery.
I would worry about the pressure capability of the 190 pump.
The regulator should be OK.
I build custom dual pump kits if you want something guaranteed to work.
Feel free to give me a call.
