how big of injector with a dry shot 150-200 hp?
was looking into a dry shot, right now i have stock flow matched #28.8
i'm thinking of the ford blue #39lbs, that flow 45lbs. i have most of the supporting mods to fuel system currently. any thoughts?????
Guess it also depends on other mods you have. Way back when, I was told 42 lb/hr injectors were fine for I/H/E H/C and a 100 shot. And that's what I used... for a few weeks. I now have Siemens 60 lb/hr injectors and plan to go up to a 62 jet (150ish) dry. Probably way over kill though.
82-02 V8 Ford Racing 39 lb Hi-Flow Injectors [M-9593-M39] $289.99
Click to enlarge
Ford Racing 39 lb Hi-Flow Injector Kit (Set of 8). Ford Racing normal price on these injectors is $399.99 Get them here for $110.00 Less!!
(Around 45# injectors in GM Vehicles)
Flow Rate: 39 lbs/Hr @ 39.15 psi Type: EV6 Impedance: 11-18 ohms 8/pkg
Welp, the only way to be certain is buy them and gradually increase the shot while continuously monitoring/logging your injector duty cycle and checking spark plugs. If you stay under 80% with the 200 shot, you're fine. That's what I had to do. If the Ford 39s are too small, just sell them and buy bigger ones.
