Will I need new fuel injectors or will my stockers be sufficient?
So after I have the ported heads on and along with my other mods which include ls6 intake and TSP Torquer II cam with all supporting mods will I need bigger injectors or will the stockers keep up? What is the factory injectors lb/hr rating? I know I have been posting alot of different threads over the last couple of weeks, but just want to make sure that my camaro will be on point.Thanks for all the help my fellow LS enthusiasts.
Ok so I dont really have much knowledge on fuel injectors so how will I know what will fit how many pounds etc. also I would greatly appreciate it if someone could point me in the right direction for some cheap 40# or 42# injectors which, where.
I have a baby cam and I just put hand ported 241 heads on her last night. I ended up throwing on some fast 36lb injectors (the white ones) at the same time. Car runs great. You will need car tuned if upgrading injectors to avoid flooding the plugs as well as better driveablity (can surge and splutter not tuned). As a rule of thumb injectors will handle as below :-
26lb = up to 250rwkw
28lb = up to 280rwkw
36lb = up to 330rwkw
42lb = up to 380rwkw
60lb = up to 460rwkw
80lb = over 500rwkw
Hope this helps.
80lb = over 500rwkw
Hope this helps.
I ran a set of TSP stage 1 243 heads,TV2 cam and a LS6 intake on my 98 and the stock 28.5# injectors were fine. Only after I went to Fast 90/90 setup did I go to 42#s. You won't know until your tuner tells you for sure!
