Racetronix vs walboro 255
Quick question I currently have a racetronix walboro 255 in the car now and I am getting ready to add a second pump to the mix. Is there any difference in the racetronix version other than the case? I would like to just pick up a regular walboro as they cost less than the racetronix. Or am I going to have to spring for the second racetronix version?
Pumps should be the exact same. The sleeve and the install kit is different for the RT kit. Watch out for the china knock-off Walbros. I hear they are running rampant.
LS1TECH Sponsor
Our pump has a jet-pump feed system which is unique. Off-the-shelf Walbro pumps do not have this feature. You can not use two in-tank pumps and maintain the jet-pump system. Please read our web ad which explains this function.
http://www.racetronix.biz/itemdesc.a...PA-001&eq=&Tp=
If you chose to remove your system and replace it with two standard Walbro 255LPH pumps we offer them in our web store as well starting at $87.50 each:
http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc=
We carry a full range of filter socks, connectors fittings and wiring as well:
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Kleeborp the Moderator™
The Racetronix pumps cost more because of the modifications they do to them so that you can retain the factory venturi system that keeps the bucket full of gas even when the tank is low. For that reason alone (and it would be a reliability thing), I would get the Racetronix pump.
Now you have my attention
I just recently installed a Racetronix 255 pump in a friends SS on a fuel system swap I did on his car. Seems to work great. I personally just went with a single 340 Aeromotive pump because it's way better then a 255 for the power I am making.
For a few dollars more, just get the 340 pump
My build is a 99SS I just did a fast 102mm intake manifold swap, SLP CAI, pacesetter longtubes, TSP ypipe, and SLP loud mouth II exhaust. Next is a yank converter and LSA comp cam swap. I also have a FAST precsion flow 36LB HR injectors waiting to install before the tune. What fuel pump should I go with? racetronix 255 pump???also would is that all I need to purchase is the pump? should I get some aftermarket fuel filters? What is a Racetronix fuel pump assembly? do I need to get one of those too? Also what does LB-HR mean on the fuel injectors?
If your interested in a real racetronix pump I am getting ready to pull mine in a week or two to install the non venturi 255 walboro pumps all you would need is the racetronix harness to hook it all up. Mine has 15K miles on it and works great.
Please help!! So lost! Please text or call (925)766-7694. It would be a miracle for me if you could get back to me asap. Im in another state and mt whole schedule is backed up because of this. Thanks!
LS1TECH Sponsor
Hi man. I am in a HUGE time crunch and need to talk to you ASAP. I supercharged my 2002 c5 z06 (a&a v3si kit) and i have a kennebell boostApump and a walbro 255 from amazon installed. I went to dynotune it today and ar 4800rpm my fuel pressure plummeted to the 40s. My tuner said i need more fuel pressure but im confused because tons of guys make 600+ just fine with the 255+boostApump. Whats going wrong here? Car made 511whp at 5500rpm before the powerband which is where my tuner let off because fuel pressure kept dropping.
__________________
>WEB SITE<
>WEB SITE<
