Will I be fine with a aeromotive 340
Old 03-15-2012, 02:36 PM
edge04's Avatar
Default Will I be fine with a aeromotive 340
Will the stealth pump support at least 650-675HP crank HP? Here are my dyno maps. More info needed?
Old 03-16-2012, 07:16 AM
Fosnot's Avatar
Assuming my calculations are right... you should be pushing 470cc/min of fuel per injector at 600 horsepower w/ a supercharged application, given that you have 69.5psi of fuel pressure.
x8 injectors = (3760cc/min total at 600hp)
3760cc/min = 225600cc/hr
(225600cc/hr)/1000cc= 225.6L/hr
something to consider is actual engine output prior to driveline loss, as well as keeping pressure constant. But it would seem that based on that math you have plenty of room (which should equal good pump life)
Old 03-16-2012, 09:17 AM
edge04's Avatar
^^ Thanks
Anyone having any issues with this pump? I have a hot wire kit that will go with it.
Old 03-16-2012, 10:00 PM
stangtrader's Avatar
good question not alot of people seem to be using them.waiting on my hot wire and pump.im planning to try for 600 rwhp
Old 03-17-2012, 07:31 AM
Old Geezer's Avatar
What type of regulator are you using??
Old 03-17-2012, 09:16 AM
edge04's Avatar
its a magnafuel boost regulated
Old 03-18-2012, 09:57 AM
edge04's Avatar
a lot of people are using these or they don't make a lot of them, pleenty of places out of stock and back ordered. found one at summit
Old 03-18-2012, 10:58 AM
MikeFSKSpeed's Avatar
Which part number are you looking for? PM me, I have a lot of Aeromotive in stock
Quick Reply: Will I be fine with a aeromotive 340
