magnafuel 750 or aeromotive eliminator for E85?
I'm interested to hear feed back on which of these pumps you guys like. I know the 750 is a great pump, but I'm partial to how the eliminator looks.
Does anyone know if the eliminator will be capable of supporting 800-900 rwhp on E85?
forced induction and fuel injected
Depends on a few thing:
1. Auto or stick?
2. What size injectors and base pressure will you be running?
3. Street car or track only?
I see you are right down the road from us. Lots of local guys running the 11104 on the corn with great results!
1. Auto or stick?
I obviously don't have the expertise of Aeromotive here, but i'll be running the magnafuel 4303 on the TA with corn and an s480. It's cheaper, and a lot of turbo guys on the bullet run them. Again, I have no personal experience with either of them.
80lb/hr injectors x 8 injectors = 640lb/hr
640lb/hr / .65bsfc (gas) = 985 crankshaft hp
E85 requires about 30% more fuel so.....
640lb/hr / .845bsfc (E85) = 757 crankshaft hp
You will need larger injectors to reach your goal. If you choose to run the 11104, you will also need the speed pump controller to drive it on the street.
