Got a couple of E85 fuel hose questions
Old 09-12-2012, 12:50 AM
Baker1k's Avatar
Default Got a couple of E85 fuel hose questions
Im looking into swapping my 01 ws6 over to e85 and wondering if anyone knew how much fuel hose to buy before I start? From what I have gathered I need aeroquip -8an for the main and -6an for return. Any information would be greatly appreciated I searched and had no luck. Trying to get everything I need before I start to cut out on down time.
Old 09-12-2012, 12:54 AM
BuffJoeyD's Avatar
You can run E85 on stock lines, but you are gonna need a bigger fuel pump and injectors.
Old 09-12-2012, 01:16 AM
Baker1k's Avatar
I have two walbro 255s and 60lb injectors its not going to be forced induction right now just e85 and some laughing gas. I thought the stock fuel line would break down because of the e85 that would be great if I could use stock fuel lines.
Old 09-12-2012, 02:30 AM
BuffJoeyD's Avatar
Exx was started to be used in the late 80s, most anything worth its salt can run E85 and ( for the most part ) most cars can run it without any real changes. I ran it for 2 years on the stock system 60lb injectors , 1 walbro 340, @ 420 hp you are good with 1 pump
Old 09-12-2012, 11:00 AM
Baker1k's Avatar
My current setup is 415whp on 91 oct but going to put a 125 wet kit on top of it.
Old 09-12-2012, 06:14 PM
Camaro9969's Avatar
I would use PFTE Teflon Lines. Its a little more work connecting the an fittings but its better than the rubber lines. I used to run rubber lines and the smell comes through the lines a lot and if you know e85 it smells nasty!
Old 09-12-2012, 10:33 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I have E85 compatible lines in stock for your appication.
Please call to discuss in more detail.
Old 09-12-2012, 11:33 PM
blackLS1m6's Avatar
I'm getting ready to convert to e85 as well and from the info I have gathered you can run it on the stock fuel lines and fuel system without any problems. (Vehicles 87 and older will have corrosion problems with e85) As long as your fuel system can provide 20-30% more flow your good to go. Keep in mind when tuning us lambda instead of AFR
Old 09-13-2012, 02:08 AM
BuffJoeyD's Avatar
Most people get confused by Lambda, you can tune in AFR. Its just a slightly richer value.
Old 09-14-2012, 02:26 PM
burbalanche's Avatar
ptfe teflon lines also!!
Old 09-14-2012, 03:06 PM
Baker1k's Avatar
Well if the stock lines will work I may just go that route for now and change everything up when I go FI down the road.
Old 09-15-2012, 02:10 PM
Baker1k's Avatar
Would 1 walbro 255 gss340 be enough to run e85 and a 125shot with 60lb injectors or should I just go ahead and run both of them since I already have them?
Old 09-16-2012, 10:32 AM
Boosted Firehawk's Avatar
2 pumps
Old 09-17-2012, 05:53 PM
Baker1k's Avatar
Ok thanks
Old 09-24-2012, 08:07 AM
2JZFC's Avatar
Most cost-effective solution is to use Aeroquip AQP socketless hose and anodized aluminum push-lok fittings. The AQP hose is made from synthetic rubber and is 100% E85 compatible.
Old 09-24-2012, 11:51 AM
jeeves744's Avatar
For mine I used -8an line to run from the tank (i have 2 pumps 1 for n/a and the second kicks on with the nitrous) and I used the stock fuel line as the return. If you are using aftermarket fuel rails and fuel regulator Jegs sells a push lock fitting that can connect the stock fuel line to the aftermarket rail/regulator (its only a couple bucks).
Old 10-01-2012, 10:06 AM
socketless is NOT the way to go for E85.
atleast thats what Nastynate says
Old 10-01-2012, 11:42 AM
2JZFC's Avatar
Really? Lemme guess.....the hose is going to pop off.
Old 10-01-2012, 11:47 AM
oange ss's Avatar
LS1Tech 10 Year
why ?
Quick Reply: Got a couple of E85 fuel hose questions
