am i getting enough fuel??
Old 05-01-2013, 06:48 PM
k_stewart_21's Avatar
Default am i getting enough fuel??
after boosting my lt1 with 10psi, trying to get the tuning right while haveing problems detonating.fuel set up is as followed:stock fuel pump, t rex inline boost fuel pump, stock regulator, 60lb injectors. fuel pressure is 47psi, AFR is at 10 wot. was having maf prblems but i believe those are fixed. what do you guys thinks??
Old 05-01-2013, 09:00 PM
05_quick4door's Avatar
Commanded is 10 at wot or the wideband says 10 to 1 at wot?
Old 05-01-2013, 09:03 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Either way, it has enough fuel.
10:1 is rich.
Old 05-01-2013, 09:27 PM
10 to 1. ok so why do ya think it is detonating? it does it at anout 5000 rpms. would octane level have anything to do with it?
Old 05-01-2013, 09:44 PM
Pull some fuel out of it. Rich mixtures detonate too.
Plus depending on what wideband it is - 10:1 could be the furthest it reads. You could be in submarine arfs
What's the timing look like
Old 05-01-2013, 09:49 PM
i aint sure about the timing, but now at 4500 it seems to cut out and power down no matter how much gas i give it.
Old 05-01-2013, 09:53 PM
You sure its not blowing the spark out? You are leaving a lot on the table with <10:1 afr
Not knowing what the timing is though is a problem in itself.
Old 05-01-2013, 10:16 PM
your the second to suggest that. im running ngk tr 6 plugs gapped at .30. a machanic where i work suggested going to ngk7s and tighing up the gap
Old 05-01-2013, 10:17 PM
ed wright does my tuning thats why idk what the timing is.
Quick Reply: am i getting enough fuel??
