Corvette FPR and Russell fittings question
Old 01-12-2014, 10:50 PM
ckpitt55's Avatar
Default Corvette FPR and Russell fittings question
Hey guys, tried searching but couldn't find an answer.
I was wondering if anyone has successfully used the Russell push-on fittings w/ the threaded retainer (PN#'s 644120 / 644110) on the corvette fpr? I only have one fitting from my fuel rail to test fit but it looks like the fittings might interfere with each other on the inlet / return lines.
I've seen lots of guys use the clip-on style fitting, but I'd like to use the threaded ones as they have a much more secure attachment. Fuel plumbing is not something I'm willing to take chances with.
Any input is greatly appreciated.
Thanks,
Chuck
Old 01-13-2014, 07:04 AM
Old Geezer's Avatar
No problems w/ the ones we've used.
Old 01-13-2014, 07:40 AM
Realcanuk's Avatar
I have had one pop off on my main fuel line and pour full fuel flow right onto my headers on my corvette. This happened on the highway and was one scary experience. I would never use one again. Now I use only swagelok fittings for this.
Old 01-13-2014, 12:22 PM
ckpitt55's Avatar
^^ exactly why I'm not using the clip on style.
This is how the threaded collar style attaches:
You'll shear the line before the fitting comes off.
I ordered the other fittings I need for it, we'll see if they fit.
Old 01-13-2014, 07:12 PM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
https://ls1tech.com/forums/17925673-post43.html
Old 01-13-2014, 11:07 PM
ckpitt55's Avatar
Good deal Mike, thanks man
Old 01-14-2014, 06:39 AM
forcd ind's Avatar
I use one of the #8 screw on like you show on my LS3 fuel rails, been on a year and leak proof-highly rec.
Old 01-20-2014, 02:29 PM
STEEPSS's Avatar
SAME!
Happened at WOT at the top of third!
AN only for Me from here on out.
Old 01-23-2014, 01:00 AM
Streetlegal?'s Avatar
Originally Posted by STEEPSS
SAME!
This has happened to me a couple times now actually. I need to get one of the collared screw in ones. Going to order one right now actually.
Quick Reply: Corvette FPR and Russell fittings question
