bungs in plastic tank?
If you do end up putting a bung on the tank, make sure the seal is above the fuel level.
Im referring to putting a bung in the bottom of a stock plastic take to feed an electric fuel pump and regulator and route a return back I guess through the top of the tank? Sorry I should of explained myself more
From what I've read, it has been done multiple times. The negatives I have read is that some guys can't get it to seal right and it leaks. Other guys have said that they never go below a 1/4 of a tank bc they don't want to chance sucking in air and ruining the pump. Recently on ls1tech and other sites there has been a video of a white T/A pulling the wheels on the street against a GTR. It appears he has a -10 or -12 line plumbed into the bottom of his tank. I would find out who he is and get his 2 cents.
use this product...
http://www.hellmannperformance.com/p...mann-fuel-sump
they work great....
dont use with E85 unless you get a seal made for e85
or you can use some permatex Motoseal and not have issues with e85
they work great....
