Dual In-tank pumps with Racetronix components
Old 03-10-2014, 02:41 PM
LS1TECH Sponsor
Racetronix's Avatar
LS1Tech 20 Year Member
Default Dual In-tank pumps with Racetronix components
We have been getting many questions about which items are required and how to use them when building a DIY DP system. In an effort to consolidate this information and help our customers we have created this thread.
If you are decided on installing a DP we offer the widest range of components at very competitive prices. Our fueling components and wiring solutions are more complete and well designed thereby reducing the amount of work required for assembly while improving performance and reliability.
Here is a list of parts required for the in-tank solution:
Here are some power harness components. The pressure switch and connector are not needed for N/A applications:
Please post your DP questions here along with basic information such as:
  • Projected FPWH (not motor build list)
  • Fuel type
  • Static or boost-referenced fuel pressure
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 03-10-2014, 03:42 PM
Stuntheavy's Avatar
I don't have anything to add at this point, as I'm still at the basis of building my fuel system.
Just wanted to say thanks for taking the time to make this thread. I'll be looking back to get some ideas for my E85 system!
Old 03-10-2014, 03:43 PM
Rise of the Phoenix's Avatar
Are you guys planning on putting together a "all in one" kit? With all these components pieced together, what would the ballpark price be?
Old 03-10-2014, 05:29 PM
wicked z28's Avatar
Interested as well on a kit?
Old 03-10-2014, 06:49 PM
gpr
gpr's Avatar
Will those dual pumps/brackets fit in the stock f-body bucket?
The following users liked this post:
Rickys2003svt.cobra (09-22-2019)
Old 03-10-2014, 06:52 PM
fly boy_1's Avatar
Im looking into buying your 510 dual pump set up and I was wondering what wire harness upgrade you would recommend for an 02 fbody. I purchased the upgraded bulkhead harness for an aeromotive 340 pump in the past, will that work? The aeromotive harness is for a single pump so if I can use that what would I need to run a second pump with it for the 255 pumps? What kind of reduction in pump life should I expect if I ran both pumps full time?
specs added
~900-1000fwhp (whatever 800whp is at the crank)
e85
boost referenced running ~15psi
1000cc injectors
Old 03-10-2014, 08:19 PM
kylemm1002's Avatar
Would also be interested I'm a "kit"
Old 03-12-2014, 01:54 AM
LS1TECH Sponsor
Racetronix's Avatar
The problem here is that everybody wants something different by introducing pre-purchased parts or their own ideas into the mix. We feel that it would be best to educate customers on the function of each item we offer so that they can make educated buying decisions. We will provide a recommended parts list based on each vehicle type shortly. This forum does not provide an advanced WYSWIG interface so posting lists and tables is difficult and time consuming.
__________________
>WEB SITE<
Old 03-12-2014, 10:23 AM
crazyelf's Avatar
Do those relays in that wiring kit offer the same "emi suppression" that this dual relay harness does?
http://www.racetronix.biz/itemdesc.a...%2D004&eq=&Tp=
I know most good relays have some kind of diode or resistor for use with pcm and such. Just wanted to clarify.
Old 03-12-2014, 10:47 AM
LS1TECH Sponsor
Racetronix's Avatar
All our automotive harnesses use sealed relays with resistive suppression. The picture in our web store does not show the new version of our DRPH which now uses weatherproof relays.
__________________
>WEB SITE<
Old 03-12-2014, 11:08 AM
crazyelf's Avatar
Awesome exactly the info I was looking for
Old 03-28-2014, 09:33 PM
kylemm1002's Avatar
Just curious if anyone has pics of this set up in a Fbody bucket?
Very interested
Old 03-29-2014, 04:13 PM
Ratical's Avatar
1400hp to the flywheel capable.
Pump+meth.
Boost referenced.
I just ordered up your DP-680 kit and have 2 questions.
I see the outlet barb fitting is only a 3/8". Do I only need a -6 line to feed the regulator or should I increase the size to a -8 or -10 to feed to the engine?
Does the kit come with the pump harness?
Old 03-29-2014, 08:50 PM
Ws6Dnero's Avatar
lq4 with small bore l92 heads. Cam with a d1sc procharger. no more than 12lbs of boost. looking for 600rwhp. What all do I need exactly?? Pm me with the list of parts needed so I can make an order asap. and I would like to see pics in a fbody bucket also if anyone has any
Old 03-31-2014, 12:32 AM
LS1TECH Sponsor
Racetronix's Avatar
Pump+meth.
Boost referenced.
We recommend a Teflon -8 feed and -6 return.
We carry these quality items in our web store at very competitive prices.
__________________
>WEB SITE<
Old 03-31-2014, 12:33 AM
LS1TECH Sponsor
Racetronix's Avatar
A single 340LPH pump will support 600RWHP with a FM FPR.
__________________
>WEB SITE<
Old 03-31-2014, 07:17 AM
LS1Tech Sponsor
hellbents10's Avatar
Very nice setup!
Old 03-31-2014, 03:20 PM
Ws6Dnero's Avatar
So what all do I need to buy?
Old 04-21-2014, 09:48 PM
SSwanner's Avatar
i have twin pumps going in now. i have the standard 99+ fbody hot wire kit but i need to know what else i need to complete install with a hobbs switch. since there is no way to call or email Racetronix its a real pain in the *** at times.... lonnies no longer will sell the dual pump hot wire kit without a complete fuel system...
Old 04-21-2014, 09:55 PM
LS1TECH Sponsor
Racetronix's Avatar
The F99 kit was never designed to be used as part of a DP system so it is not something we will cover in this thread. We highly recommend you sell it intact and put your money into the proper components. Thanks!
__________________
>WEB SITE<
Quick Reply: Dual In-tank pumps with Racetronix components
