Fuel cell vent line hose size?
Old 06-22-2014, 10:36 AM
Patsy57's Avatar
Default Fuel cell vent line hose size?
I have a nasty performance fuel cell which has -10an fittings on it.
Does anyone know if it will be an issue running a -8 or -6 line from the cell instead of the -10?
Old 06-22-2014, 04:02 PM
Torcha's Avatar
My last set up the vent line went -8 down to -6, never,had any dramas. Just make sure you put a loop in
Old 06-22-2014, 08:06 PM
VLS1's Avatar
Breather should generally be sized at least the same as the fuel outlet itself or bigger, you could also consider fitting a roll-over valve.
Old 06-22-2014, 09:51 PM
Patsy57's Avatar
Rollover valve won't work it's a street application
Old 06-22-2014, 10:14 PM
VLS1's Avatar
One way vent won't work on a street car, how so?
Old 06-22-2014, 10:17 PM
Patsy57's Avatar
It will but I have an open like with a rollover valve on it and a loop. I'm gonna change it to a billet catch can that that will separate fumes and burped gas.
Kind of like nasty performances can.
That being said I'm not a fan on a street car of just a vented line with a rollover valve in it, would prefer a check valve setup that only opens with pressure.
Old 06-23-2014, 06:37 AM
Old Geezer's Avatar
"would prefer a check valve setup that only opens with pressure."
Old 06-23-2014, 06:45 AM
Patsy57's Avatar
Like this one
https://www.pegasusautoracing.com/pr...asp?RecID=8453
It's ok I ordered the nasty performance catch can and will run a -8an line to it
Old 06-23-2014, 07:27 AM
Doug G's Avatar
All I did for a vent... best shot I have while at body shop.
Quick Reply: Fuel cell vent line hose size?
