What rails and lines?
Old 01-22-2015, 10:12 AM
ChameleonFormula3's Avatar
Default What rails and lines?
Just wondering what rails and lines I will need to work with my system.
I'm going with PRC 2.5 LS6 heads, VRX5 cam, and a nitrous outlet plat kit. Car currently has an LS6 intake with the factory rails, injectors, and lines. I already have ready to go in a racetronix fuel pump with Hotwire kit, and ford 42#green top injectors. What fuel rails would work best with my setup? I'm looking for as close to bolt on as possible without having to modify to much with the nitrous kit and what not. Thanks in advance.
Old 01-24-2015, 08:16 AM
Anyone?
Old 01-24-2015, 07:32 PM
kylemm1002's Avatar
What's wrong with the factory stuff? I'm not expert. Boosted cars make 700+ on stock rails. As long as you have the volume/pressure no reason to change it right? Unless your trying to clean up the engine bay.
Just my opinion.
Old 01-24-2015, 10:28 PM
This is my first fbody build. I have been told by several people the stock ls1 fuel rails won't cut it.
Old 01-28-2015, 01:20 PM
Anyone?
Old 01-28-2015, 05:04 PM
shepss217's Avatar
I like the holley rails and crossover line
Old 01-28-2015, 05:05 PM
shepss217's Avatar
I ran into a problem with the stock
Lines only because i got a set of truck coils and the 3rd coil was hitting the stock lines and the purge valve
Old 01-29-2015, 08:24 PM
So the stock rails will be fine or not? lol
Old 01-30-2015, 09:16 AM
Robert Cantu's Avatar
Just chose some like Aeromotive,Scorpion,Fast and get it done.. I have about the same setup as you and I'm running a Aeromotive fuel rail kit but on a Fast 90.
Quick Reply: What rails and lines?
