M6 Ls1 Driving me crazy
Ok guys on the external forums i had my fuel pump go out I had replaced it with a walbro unit ran great for a few weeks. I went to start it this morning and it started ran great then dies. I was low on fuel so i filled her up and same issue. NOW it idles and will die when put in first.... it stumbles and dies. Any help would be appreciated thank you
I got it from amazon where i got it from walbro i order an extra one just ij case. But yes at first i could rev it up now it wont do that
I checked the schraeder valve and gas spews out like crazy when pressed. When car is put into 1st it starts to stall and if i move it to neutral it comes back to life but if re'ed in neutral it will die
Update checked all fuses everything good. Checked for codes none. One of the positve cables that goes to the fuse box is exposed a bit i guess from hitting the balancer will replace along with the alternator cable
Ok guys I checked the pressure at the rail it was only about 20 psi so I guess I will be removing and replacing the fuel pump. Would the fuel pressure regulator affect flow
