Fuel Line Issues
Old 10-02-2015, 07:40 PM
YellowTA1's Avatar
Default Fuel Line Issues
I bought a set of braided fuel lines, and now I can't seem to get the stupid things to go onto the rail or the other end? I've attached some photos of what the connectors look like, is there another end I could possibly get to screw onto the ends that will go on and be more less likely to leak at a local parts store? Trying to get ready for a show, so some help and advice would be appreciated, thanks!
Attached Thumbnails Fuel Line Issues-20151002_185724.jpg   Fuel Line Issues-20151002_191417.jpg
Old 10-03-2015, 12:24 PM
YellowTA1's Avatar
Nobody has experience with these fuel lines?
Old 10-03-2015, 02:29 PM
John94chevy's Avatar
yellow ta1
remove white clip from fittinf and slip on fuel rail end over rige than puch fitting on fuel rail that white clip locks fitting in place
Old 10-04-2015, 01:14 PM
jrpimp00's Avatar
First, dont use that fitting it can and will pop off. Second it doesnt screw on it pushes on. If you have to run it now do like John94 says
Old 10-04-2015, 07:08 PM
Realcanuk's Avatar
Had that plastic garbage come apart on me on the highway. I was lucky the car didn't burn to the ground.
Used a Swagelok fitting to replace it. It can never come off or leak.
http://www.swagelok.com/search/find_...t=SS-600-6-6AN
Old 10-05-2015, 05:39 AM
Ollie8974's Avatar
2X on the Swagelok compression fittings.
Old 10-05-2015, 07:52 AM
YellowTA1's Avatar
so I will need (2) of those swagelok compression fittings for the fuel line side? Do I need to change the evap fittings also?? Anything else I need besides 2 of those fittings?
Old 10-06-2015, 11:17 AM
YellowTA1's Avatar
Ok, so it would help if I had the lines going to the correct place. The first one on the left is the one that goes onto the back of the fuel rail. the end unscrews, goes at the bottom and then pushes onto it and just tightens up. The one on the right is the other one going to the evap solenoid. Again, do I need to change both of those ends so I have no issues of them blowing off or causing me any problems?
Attached Thumbnails Fuel Line Issues-20151002_185749.jpg   Fuel Line Issues-20151002_185724.jpg
Old 10-06-2015, 10:40 PM
Realcanuk's Avatar
The one for the evap is fine left stock. It is not flowing fuel, just vapors.
Old 10-07-2015, 01:30 PM
YellowTA1's Avatar
realcanuk, can you post a pic of what yours looks like after swapping out fittings?
Old 10-07-2015, 09:20 PM
Realcanuk's Avatar
Blue fitting with plastic is one that almost killed me... LOL...
Old 10-08-2015, 12:57 PM
Ollie8974's Avatar
This is a link to all the Russell push on EFI fittings at Summit
http://www.summitracing.com/search?S...EFI%20fittings
Old 10-08-2015, 01:59 PM
YellowTA1's Avatar
http://www.summitracing.com/parts/rus-644123
that first one looks just like the one that came with the lines I have that goes on the actual fuel side with the threaded cap.....so does that mean that I don't have to change those?
Quick Reply: Fuel Line Issues
