View Poll Results: How much rwhp will a walbro 255 support
500rwhp
4
20.00%
550rwhp
7
35.00%
600rwhp
7
35.00%
600+rwhp
2
10.00%
Voters: 20. You may not vote on this poll
Max hp a walbro 255 will support. Racetronix, granatelli ect? Post your HP!
So looking to see what kind of power you guys have made with a walbro 255 pump. I have granatelli 255 pump and i will be running a 408 with nitrous and looking to see how much power I can throw at it before it will run out of fuel. I'd like to see 600rwhp.
So everybody post up the max rwhp you have made with a walbro 255 pump! Please include if you are FI or NA. I'll also make a poll for this.
Held up for about 25 pulls at 1/2 mile events so far
I hit 550 on 9 psi through a 9" and th-400 with ~ 11.8 afr. When we opened the cutout the car made 573 but jumped up to 12.2 afr. I'm running a single 255 now with stock lines and rails but 60lb injectors.
I don't think elevation has anything to do with the fuel pump. The blower produces X amount of CFM and the fueling is tuned to keep up with the engines demand as the CFM rises. If anything I would say the pump has an easier time on my car because I can't produce the same PSI of boost at the 6,500 FT as a blower spinning the same speed at sea level can. The roads I drive are in the 6,000-7,500 ft elevation range btw.
Also everybody keep posting what numbers you have made on a walbro 255 pump. Or you can post your 1/4 times and trap speeds with a single walbro 255 if you don't have dyno #'s
The following users liked this post:
NewOrleansLT1 (07-23-2021)
LS1TECH Sponsor
This is why the Racetronix FPA-001B is the only true direct-replacement for the factory pump in the ORIGINAL factory module.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
