Push connect fitting for stock fuel line to -an
Does anyone make a push connect fitting that connects to the stock fuel line with a male threaded -an end? I know there are male to AN fittings that go into the stock rubber line I'm looking to go from the stock hard line directly to a-an hose to my fuel rail.
Like this?
http://www.russellperformance.com/mc...injected.shtml
We use ONLY the screw on retainer. The plastic ones have blown off.
If you are connecting to the factory quick - connect ends of the fuel line, here are a couple of links:
http://www.ebay.com/itm/Z158-8AN-Fue...tTvhKD&vxp=mtr
http://www.ebay.com/itm/Z157-6AN-Fue...tTvhKD&vxp=mtr
Corrected links!!!!!! Thanks to jrpimp00 for catching the goof up!
http://www.ebay.com/itm/Z152-6AN-Fue...JTkhAx&vxp=mtr
http://www.ebay.com/itm/Quick-Connec...hWlBOL&vxp=mtr
Even though the OP has not returned to this post. DO NOT USE this type of fitting, many people have had them pop off and cause fires. I had one pop off on a buddies car we were tuning but didnt catch fire.
Great catch bud! I looked back at my links and realized I definitely screwed up and connected the wrong ones.
I had those stored in my watch list from when we were researching the fittings . We went with the screw on fittings, NOT the pop on! I took a cursory glance at the pic and didn't look close enough at the pic to realize my mistake.
To the OP: I apologize profusely for potentially steering you in the wrong direction. Here is the links to the PROPER fittings:
A am also going back to edit the first post to remove the bad links so no one accidently screws up and uses them!
Again, thanks jrpimp00 for catching my goof up!
