Holley fuel rail.. which injector o ring??
I am leaking a lot of fuel from my injector/rail side. What size o-rings do these use? Bigger than stock? I have ls1 injectors on a fast 102 with Holley rails. Also used the spacer kit for the rails. Need to find rings tomorrow! Thanks!!!
Tim
Tim
Bought new. Tried the old ones as well. They both leak badly. Can't figure it out at all. Just got off line with Holley they are sending me some o-rings as well. I just don't see why stock shouldn't work.
I know when I redid my fuel system I had leaks at the rails (billet), so I took the intake off therefore I could line everything up perfectly and get it leak free.. also helps to put a little silicone grease on the O-rings to slide in better..
been leak free since.. trying to align everything with half the engine under the cowl is a major bitch.
Mines on a cts-v. Alignment seems pretty simple. It's the spacers for the rails etc that don't seem perfect. I tighten it up and it pulls the injectors out of intake some. maybe I'll try all that again. I really don't like how it fits. I'd think the rails would bolt on much smoother
