Fuel Question - SIze Injector and Pump or Pumps?
OK - IF I was to go with a 383 when I rebuild My motor What size injectors do you guys think I might need and what Fuel system Upgrades do you think It would require. I have a STS kit and low boost is gonna be set at 8lbs with High being around 15lbs. On High I will be adding meth. I currently have the racetronics pump and hot wire kit with 50Lbs Injectors and stock lines. SO what do you guys think?
Bigger injectors>?
Another in tank pump>?
Do I need to Upgrade fuel lines or fuel rails>?
I am looking to put at least 600 to the rear on high boost - or more?
I thank you in advance for your thoughts. Sorry for asking a question that has bin asked B4. Lata, Arkangel77
Bigger injectors>?
Thanks for the reply - I did a calculation on the net and it said 58.somthing? So I figured at least 60's. For MY LT1 set up - do you know if I need to go with LOW impedance? I think I do? I am just looking for some input from you guys cause many have bin down this road already! Thanks Again, lata, Ark
High-imp mototron (or w/e the brand is) 60's should work well. For fuel pumps, I am a fan of sumped tanks and external pumps so I'd say go for the weldon 2015 w/ a controller (either weldon or aeromotive to cut voltage when you're not beating on it).
OK - I did not know that>? well than Just because I am stumped? What do the low impedance do or better yet what aplication are they for? It was My understanding that LT1'ns and LS1'ns used different Type Injectors and I thought that LS1'ns used High? am I mistaken?
RealQuick -I guess you are using an Impedance converter because you have thoes LOW inpedance Injectors than right? Thanks for the Help guys - Anyone got a Link to where I can find a Fair price on that KB BOOST a Pump?
Thnaks, Lata, Ark
Thnaks, Lata, Ark
Thnaks, Lata, Ark
Thnaks, Lata, Ark
KB's are expensive. If you go to KB's website you'll see them there. Racetronix like the MSD version. I think its cheaper too?? Contact racetronix (they are a sponsor on cz28.com).
SO basicaly any Good Bran Booster Pump will do than as long as it fits the aplication and I might want to think about the MSD one. I got it - thanks Bro. Lata, Ark
60lb hgih impedence injectors
255 in tank
BAP
Good luck.
WELL I Just read what it does.
http://www.kennebell.net/accessories...boostapump.htm
I already have the Pump - I need to get some injectors BUT I already have the Racetronics Hot wire Kit. I know that it is NOT adjustable BUT it sounds like it sorta does the same thing? I need to do some more reading on this BUT How could that BOST-A-PUMP put out more that what the alternator is putting out and thats what MY pump is getting threw the Hot Wire kit - I think? ILet me know If I am missing something?
Thanks, Lata, Ark
Thanks, Lata, Ark
Thanks, Lata, Ark
Thanks, Lata, Ark
