is there such a thing as too much injector?
Old 07-11-2005, 11:33 PM
half-n-half's Avatar
Default is there such a thing as too much injector?
hye guys i am getting a cam and nitrous and other things in the next month or so, so i am looking to upgrade injectors for the tune. i figure 30s 0r 36s would be good, but would there be anything wrong with going to a larger one, like a 42 lb injector and then possibly growing into it later with a 2nd dtage dry shot, or a larger displacement motor?
right now i will have a wet shot, and a large cam.
Thanks
Louie
Old 07-12-2005, 07:18 AM
oange ss's Avatar
yes there is
Old 07-12-2005, 01:28 PM
RedHardSupra's Avatar
svo 42s (48#@gm pressure) are not big at all. supra's come with 550cc injectors stock (that's like 53#) and idle like a lexus. i've seen cars with 1600cc injectors idle just fine. it's more of a question of configuration than the hardware itself.
get yourself the 42s and you'll be happy and safe to about 500-550rwhp
Old 07-12-2005, 04:43 PM
mdhmi's Avatar
Idle is only part of it. Generally the smaller the injector the better the spray pattern and drivability, although many of the drivability issues can be addressed with a good tune.
Mark
Old 07-13-2005, 09:24 PM
OlieAV's Avatar
you can run way too rich, for a start
Old 07-14-2005, 07:24 PM
MIGHTYMOUSE's Avatar
you obviously dont want to change injectors at all without the capability to calibrate the computer for them.
i would step up so that you won't have to do it again later.
i never had problems getting good idle and part throttle from mototron 60's on a 346ci engine
i currently run 96's in a 366ci engine fine but did have some problems with idle AFR control w/ same engine and 160# injectors
Old 07-16-2005, 03:40 PM
Brody's Avatar
I had the same question:
*Assuming you have them scaled properly (i have HPTuners)...
Are there ANY disadvantages to larger injectors. I heard someone say drivablity but he didn't follow up as to why. Going AFR H/C and want to be able to throw a 100 shot on it in the future. I'd rather just buy injectors once.
Old 07-17-2005, 11:37 AM
dc96819's Avatar
If your injectors are to large change the duty cycle,that might work.
Old 07-17-2005, 11:39 AM
you don't change duty cycle, duty cycle changes for you, if you change injectors/calibration. it's a derivative of rpms and injector pulse width. PCM section has stickies for it.
