42LB are good to how much RWHP with Procharger
with 8psi on a D1sc and a 255 intank fuel pump how many rwhp are the 42lb good for I have heard that 550 is the limit so is there anything wrong with going with the 60lb if I only have 500 rwhp right now, in the near future I will be looking for a little over 550 with a few upgrades thanks
Originally Posted by Blackbird
closer to 500 unless you run them static.
go with the 60's no reason not to.
especially if you know your gonna keep going for more power.
they should be good to about 600+. A local car here in florida has them in his cammed nitroused t/a making I believe in the 530 range. The injectors are between 60-70% duty cycle.
One of my customers had the 42's on his procharged H/C vette and they tapped out about 560. Went with 60 lb motrons and now has plenty of room. At 650 rwhp he was only 73% DC on them.
John
John
I did the setup on 2000Silverbullet's TA and used a Racetronix PnP kit with the SVO 42's. They worked good at 525rwhp, but they are maxed out at 570rwhp. He is running a P1SC at 9-10lbs of boost. I'm going to either going to raise the fuel pressure a little or stick some 60's in it in the next few weeks.
Originally Posted by kp
No reason not buy 60s at all if you are buying new, they are pretty easy to tune and the car will idle fine.
42's are great for the average car! I would not get them if you have big plans to spend big money! After you spend 15k plus > you will need more than 42's....Anyone want to send me some mac-a-roni and cheese? I dont have money to eat now....
Are the 60#'s just a PnP with the correct tuning? I thought 60's were lower impedance and you needed driver boxes? Or are there high impedance 60's now?
I want to get some 60's for my STS setup, but was told I need to get the driver boxes.
