Inspector 12-fuel questions
Old 09-16-2005, 10:18 AM
Got Me SOM's Avatar
Default Inspector 12-fuel questions
What is your fuel setup?
Looks like I gotta get me some 60 lbers. it never ends...
Old 09-16-2005, 02:55 PM
JMBLOWNWS6's Avatar
He pretty much has what I have. He will be using a dual walbro intank setup on a modified stock bucket. Runing the bulkhead out of it to a -8 an feed line with the stock return (Old feed line) and the fuel filter blocked off. Using LS1 speed Inc fuel rails and regulator. I am also using there inline fuel filter for the feed. If Im not mistaken he is also using stainless line instead of steel braided lines. I could be wrong but thats what we hammered out since he and I are on the same page on the fuel system
Old 09-18-2005, 11:19 PM
TT-TECH Veteran
Inspector12's Avatar
JMBLOWNWS6 is right I am changing basicly what he said, but what I have now is fine for my current power level. Walbro plug and play (I didn't use there wiring though.) And an MSD Boosta pump with MSD 55# injectors and stock fuel lines. If you install a fuel presure regulator in the return portion of the stock fuel lines (Where the T is in the back.) It will hold steady presure and will be good for a lot more than what I am doing. (713)302-0737 if you need clarification on what I told you.
Old 09-19-2005, 06:50 AM
Got Me SOM's Avatar
my friend has 50 lber's all I need is a BAP then, you said you were getting rid of yours, how much did you want for it shipped?
BTW the car bounced off the rev limiter Sat night and blew out the MAF. Thank god all I had to do was unplug it and limp home. Luckily I had a spare one in the garage.
Think I'm gonna enjoy the car as it is for a while before I push it anymore.
Old 09-19-2005, 06:56 AM
Got Me SOM's Avatar
why am i putting a regular on the return portion ? just curious.
Old 09-28-2005, 05:14 PM
TT-TECH Veteran
Because I said so LOL! Think about it and get back to me. Look at the design. I will sell it for $200 Shipped.
Old 09-28-2005, 05:39 PM
JMBLOWNWS6's Avatar
What funny about this whole deal is I change my setup AGAIN One day Jeff I will call you and have my mind made up
Old 09-30-2005, 08:24 AM
TT-TECH Veteran
And mine is undergoing surgery as we speak I put it on the rack last night and I don't think it wil take me long to get it set up the way I want I will take some pictures of it for you JM, and let you know how it works or doesn't etc...
