F-body fuel pressure regulator removal
Ive got a 99 camaro fuel pump/sender and I need to remove the fuel pressure regulator from it. I know its located in the tank on the sender/pump assembly but Im not sure what it looks like or how to remove it. It looks to me like the there is a line that runs right off the actual pump directly up to the top to the outlet(to fuel line). Im also not sure how to remove the plastic surrounding to actaully see in it.
Any help is appreciated!!
thanks
thanks
Its a little green half dome looking thing with a small tube protruding out of the side.
If you look at the sender where the lines connect to, its right under the one that has an "R" marked on it.
It's held in with a clip, just remove the clip and it should pop right out.
Looks like this? (this is on a 98 so its a little different mounted I think)
thank you!!!
