T/B disassembly question
Can anyone tell me if there is a special torx bit needed to take the throttle body on an LS1 apart? The heads on the bolts look like a normal torx fitting, but they all have a pin in the center as if the end of the bit would have to be hollow.
Originally Posted by Shooter9
What type bits did yall use with the drimel tool? Any help would greatly appreciated. Thanks in advance.
I stripped mine with a reg torx, and had to put a slot in and use a flat screwdriver and a little heat to get them out. i bought some stainless button head allen screws to put it back together.
The bolt heads that you are describing are tamper-resistant (pin-in-head) Torx fasteners. They make special bits for these bolts that can be found at Sears (easiest place). You can buy them as regular L-shaped wrenches, bits for hex drive tools, or bits that are attached to sockets.
-Jay-
-Jay-
