42lb Ford Lightning Injectors?
Im currently running these in my GTP, they are the 'Green' injectors...
Am I able to use these with the LS-1?? (with tuning, obviously)
I did a search, and all I could find that people use were the 42lb SVO injectors..... same thing?
Thanks!
Thanks!
Yes... ~36lb Injectors.....
Theres another thread floating around here with that very question...
Those injectors are fairly cheap, and very common.... Im guessing they
will work fine with the proper Injector Flow Rate table in the PCM....
The GTP injectors will work i believe i read on here some got 470rwhp with alittle room to spare. Stock offset table too with these i read also.
I'm running them and yes they can be had very cheap i got 8 of them for about 70 bucks. Don't know how good they are myself the car isn't running yet, and the guy that's tuning my car said it will need tuned to run cause the injectors are to big.
Originally Posted by NVR_ENUF
Oh and if you guys wanna find some SVO 30's or 42's fairly decently priced go to the classifieds over on www.corral.net there is always injectors for sale over there. I got my 42's with a 90mm mass air meter for my stang for $300.
