Anyone else have a nasty perf.fuel tank
I swear mines only 10 gallons...its empty in like 110 miles now...Site says its 15 but i dont think so, its also visibly smaller then stock. Anyone? Nate?
i got mine back in september...not sure how much is left but the check fuel light comes on about 110 miles now...before it was 200ish? Im gonna empty it all out an fill it 5 gallons at a time when i install my second weldon a600, imp retty sure it came with a sending unit
This is the way I look at it. I got on the X mas special he had. So the Tank and fuel rails came as a package. I allready have fuel rails so I sold them and got the tank for under $460. It is a quality part. Is it worth it? Well to me yes. Since I am forced induction I feel I shouldnt skimp on the fuel system. And this fuel system is the best IMHO. Nate also treats his customers right and is a great person to deal with. I have asked him a ton of question and every question has been answered.
Originally Posted by BLk01SS
are they worth it?? I'm debating buying one. Would you do it again or just stay with the stocker?
I'd do it again. I had a few snags(dent t-top well to clear fitting, made longer tank straps,baffle didn't clear stock sending float, figuring the venting out) on the install but nothing major. This was on the first run. Dont' know how many revisions have been made since then. The easy thing I see is that the pump/filter assembly is now mounted on the driver side.
Forgot to add that Nate was a pleasure to deal with .
I went over it with Nate. When he sends the rest of my system out I allready outsourced http://www.atlltd.com/ventvalves.htm Then topping it off with a K&N little filter like the ones we use on the air system when switching to a aftermarket lid. Now to find something like that in the US But I think the roll over valve will work just fine http://www.dougherbert.com/8rollover...e-p-12887.html
I think you are right it is about 12 gallons. we had done a quick dimention measure and got about 15 but I think real world fill is about 12. There has been many updates to the tanks as as we come by an issue we try to fix them. The sender was replaced with our custom fit one to eliminate level problems. The straps I have heard of some needing a little extra length some dont but longer bolts works. As far as I know there is no issues with the current tanks that people have let me know of. We try and provide the highest quality products we can.
Thanks Guys
Nate
Thanks Guys
Nate
ya 12 sounds about right since i get about 10mpg thanks guys, oh and if your thinking about this tank and dont mind less fuel...its built to prerfection an goes in like butter...nate does a good job...although his 1400hp rating is off, I ran out at 800hp
I agree, my tank fit fine. It seems like I put in just over 5 gallons of fuel before my gauge even registered anything was in there.
