Which fuel pump??
Which fuel pump??
I am stepping up to at least a 150 NX shot. I am still running on the stock fuel pump. Which fuel pump do I need to get? I have heard about the Walbro and the Racetronix. I have not heard anything bad about the Racetronix, but I have heard that the Walbro does not do well with under 1/4 tank of gas. Please help me make the right decision!!!!!!!!!! Thank you
Go with the Racetronix In Tank Pump and PnP Wiring Harness.
Some like to do the Trap Door method of pump removal/install - I prefer to actually drop the tank (really not that hard) plus the tank really should be cleaned prior to the install of the new pump (Racetronix highly recommends this).
What year vehicle? The Racetronix kits are nice as they are plug and play, and you don't have to hack up the factory bucket. More info:
http://www.harrisspeedworks.com/shop/home.php?cat=330
Matt
Matt
Definately do the Racetronix setup with the PNP as 1QuickWS6 stated. It's a great system. I'm running it and have zero complaints. It works well.
The trap door method for installation works great and makes things much easier and quicker. That's how I installed mine.
Originally Posted by bluehawk2
Thanks for all the info. Looks like I will spend the extra big bill and get the racetronix. Where is the best price on the this pump? Thanks
I am sure that the walbro will support the 150 shot just as well as the Racetronix, however the racetronix is a easy pnp system and the you have to mess with the bucket with the walbro. I have heard of several people running out of gas at a little less that 1/4 tank with the walbro. I guess the pump over heats. Someone correct me if I don't have this right. As of right now I will try to get a GP on the racetronix.
My walbro works fine and I run my tank to almost dead empty quite often. Matter of fact I filled it the other day and the tank took 14.6 gallons to fill it. Install is pretty simple and since the price is cheap for the walbro I just did that. Although I hear nothing but good things about the racetronix kit.
Matt
Matt
One vote here for Harris speed works. Thanks Matt for getting my order fixed.
Justin
I believe you have it turned around a bit. The rubber hose that comes with the Walbro pumps is the inexpensive one that will break down over time.
Matt
Matt
Originally Posted by Dom
The Walbro kit comes with a high pressure hose to replace the accordion stock one. Why does the Racetronix one use the same kind of accordion hose instead of a high pressure one like Walbro? I mean it's so expensive and they cheap out on the hose.
Matt
Matt
