What are the DANGERS of Meth injection?
Like its says, what are the dangers and down falls of a meth-injection kit??
I.e what happens if you run the tank dry and go haulin *** down the street, And so on? Kit would be going on a built engine with about 16lbs of boost thru a d1sc!
So, with that in mind, keep your tank filled!
I've never used it, but I thought it was corrosive to aluminum and accordink to wikipedia I was correct: "corrosive to aluminum, importantly aluminum parts in engine fuel-intake systems"
http://en.wikipedia.org/wiki/Methanol_economy
what saftey requirments would you reccomend for a system that will be supporting 700+rwhp
i would have a 'pump running' light and a 'meth low' light at minimum
i also have a purge button that i can check the system anytime i want to verify function other than flooring it and trusting it will activate properly
