guys with 60lb injectors, whats your RWHP?
Old 02-23-2007, 09:06 AM
7 Second Club
ty_ty13's Avatar
Default guys with 60lb injectors, whats your RWHP?
i just got my car dynoed and much of it didnt make sense.... im thinking i might have been driving through the converter.....
it made 573@ 5750rpms and its injector duty cycle is 90%.....
what injector duty are you guys seeing with your horse power?
yes its a good fuel system with enough pressure..... the guys at EPP did the dyno...
its a nasty cell -8line, magnafuel pump, billet rails.
Old 02-23-2007, 10:06 AM
black98ws6ta's Avatar
Is the fp rock solid? Or is it boost referenced?
Old 02-23-2007, 10:09 AM
Pathological Modifier
Ryan K's Avatar
673RWHP/802RWTQ @100% DC without a boost referenced FPR. and 16psi boost (60psi fuel pressure-16psi boost=44psi across the injector).
Ryan K.
Old 02-23-2007, 11:17 AM
Coal Mining Director
onfire's Avatar
710rwhp through a T400 with 86%DC with a FPR set at 60psi...rail pressure increased to 77psi but the injector only saw 60psi.
Old 02-23-2007, 11:25 AM
BLNLS1/RX7's Avatar
If EPP did the install and the tune for the new injectors you have recieved the best and most proffesional service that money can buy in North America period
kp
kp's Avatar
Thas about right for an unlocked TH350 on a mustang dyno..
I hit 650s on a dynojet with 60s at 100% DC with the T400.
Old 02-23-2007, 11:53 AM
7 Second Club
ty_ty13's Avatar
im really more worried about the converter at this point.... it flashes to about 5k but my peak HP and TQ is at 5750ish..... i'll keep you posted on times...
all i know is it is a beast!
Old 02-23-2007, 11:55 AM
7 Second Club
ty_ty13's Avatar
i will say that i am very impressed with those guys..... jake, brent and bob and dianne are awesome.... very nice, very smart, and very hard workers... i cant say enough about them.... i wouldnt have to think for a minute if i had to have another car professionaly dyno tune or install.....
Old 02-23-2007, 12:33 PM
qqwqeqwrqwqtq's Avatar
I ran them to 820rwhp through a T400, 100%DC, 73.5 base pressure (boost referenced).
Old 02-23-2007, 12:42 PM
kp
kp's Avatar
Mine flashes to 5500..
Its a race car not a dyno queen.
Last time I had mine on a dynojet for some reason it wouldnt even crack 600 and it still ran 9.40s @ 144
Then I tried it again later in the year and it did 68x, and ran 9.40s @ 144 lol.
You did what you needed to do, if the fuel pressure was holding and the inj DC was that high and the a/f was in line then it was making some decent power, just go run it - thats what you built it for right?
Old 02-23-2007, 01:05 PM
7 Second Club
ty_ty13's Avatar
you damn right its no dyno queen... lol... i know that with all the stuff its moving its making some serious power... i just hope i can hit some 6.500 in the 8th this spring with out throwing more money at it.... cause im broke
i also know that it being a mustang dyno tells a lot too... on a dynojet its atleast 600rwhp... plus the 3speed tranny with a huge *** unlocked stall...
Old 02-26-2007, 04:44 AM
EPP
EPP's Avatar
Smile
Thanks Tyler, we appreciate it! Bob
Old 02-27-2007, 10:57 PM
Jimmy P's Avatar
My numbers are very similar to yours, and my 60lb injectors are at maxed 99%. I am starting to think its our ATI converters. Mine seems REALY loose uptop. It seems like they did KP's just right, since he is finishing the traps at 144mph, but my top speed is no where near that.
Old 02-28-2007, 10:50 AM
7 Second Club
ty_ty13's Avatar
i'm going to bowling green sunday to make some passes... ill let you know
Old 03-01-2007, 10:35 AM
cjmatt's Avatar
i laid out 520 rwhp on my 60s, base pressure of 43psi. will raising my base pressure when I retune allow me to squeeze a little more out of them as I am planning on adding a substantial amount of boost to the setup and dont want to change injectors if i dont have to being that I am an lt1 and a 60 is the most the PCM will control. I am also using an aeromotive boost referenced FPR
Old 03-01-2007, 10:50 AM
EPP
EPP's Avatar
Smile
Yes it will. On the LS1 engines we start out wih 58 to 60 psi of pressure, and 60's get us up past 750 rwhp. Bob
Old 03-01-2007, 05:17 PM
Jake@EPP's Avatar
You can do the RC 72lb injectors with stock computer, also with a versafuler you can run low impd injectors.
Old 03-02-2007, 08:34 PM
thosewhohatedmecreat's Avatar
I always heard anything over 80% cycle rate is bad. lol. sorry, but is this true?
