Where are you tapping into the fuel pump wire for bap install??
Originally Posted by 98turbls1
I'm doing a KB BAP install and want to know what color the fuel pump wire is in the back of the car. it's a 98 Camaro so it may be different from 99+.... Any help would be appreciated...
How do you check the difference between the two (sending unit and fuel pump)...Mine is a 98 if that makes a difference...
Problem with that is that the gauges have power at that point also, including the fuel gage - allthough, since the fuel gage is like a rheostat, and has some range of ohms (usually 0-90) that it outputs based on fuel level, it should be easy to weed that out.
Sending unit on mine is Purple & Black with white stripe, while FP is Gray wire & Black wire. Some years used Red wire & Black wire for FP. By process of elimination you should be able to find the correct wires by probing if you go thru the colors I mentioned.
I could be wrong - I'm a ME not EE
I've done searches many times and even asked a couple of times...Needless to say this is the first time that I've received an answer...Most responses before were to get a racetronix hot wire or whatever... Thank you to everyone that has put forth effort to help out a fellow techer...
