fuel pressure issue...Strange
Background: Bought my 98 TA WS6 3 mo ago. Took to track a week ago and couldn't get below 14.6 even when hooking. Got back from track and changed plugs, wires, fuel filter, cleaned K&N. Went back to track last night improved to a 14.1. Still too slow for this car. My 60's are decent at 2.15 but can't break into 13's or exceed 100mph.
So I decide it has to be a fueling issue (too lazy to do a compression check at this point). I check fuel pressure w/o engine running. It seems good at 54 lbs (very minimum for these cars). I start the engine, and the needle on the pressure guage starts vibrating really fast b/w 60 and 70 lbs constantly. Pressure is supposed to drop w/ engine running. What could this be?
Key on, engine off results in lower voltage to the pump. Engine running, the alt is now in the picture, and the voltage rises. [Hopefully, anyhow.]
Also, if the ecm does not see cranking rpm, the pump will time out, and may not get to full psi in the short time it's on.
fuel preesure
Let me restate the issue:
I check fuel pressure w/o engine running and key on. It seems good at 54 lbs. I check again with the engine running, and the needle on the pressure guage starts vibrating really fast b/w 60 and 70 lbs constantly. Pressure is supposed to drop w/ engine running. What could this be?
How about..
8 sec potential, 12 sec slip
Your stock fuel pressure is supposed to be 58psi. It will fluctuate a little with the engine running (between 58-60). So, your pressure is not "good" at 54, it is low. Why do you think the pressure would go down with the engine running??? It should stay the same, but it will go up as stated above because your pump is getting more voltage from the alternator.
d
follow up
stock pressure on mine was about 58 at idle, and 60 at part throttle...
something is definitely fishy tho if you are seeing 70 at idle. You sure your gauge is accurate???
