evap removal question
Ok I did a search and couldn't find any definant answers.
Is this the way to remove it?
Its a 98 btw.
Remove the canister and the line that runs to the front of the car to the intake. Cap the intake off. Cap one of the lines coming from the tank and put a rubber line on the other with a filter for venting.
This is a race only car. I'm not worried about gas smell or emmisions. I only need to know if this is the correct way to get rid of it.
Also which codes will I need to delete in the computer?
Its a 98 btw.
p0442. p0443. p0446. p0449. p0455. p0496. p1665. p2025. p2026. p2027. i think that is all of them. its mainly a environmentle thing not even straight up emissions. glorified way for a gas tank breather to prevent vapor lock.
My installer who installed my cam, capped the EVAP line in the engine bay and on the intake, and just had the EVAP system tuned out. I'm pretty sure there's a whole lot more I could do, but it just cleaned up my engine bay a bit
If you do not vent the tank and run a vacuum line to the evap line going to the tank you will create a vacuum on the tank and cause it to collapse in on its self since their is no fresh air allowed to enter the tank.
The evap system has a vent solenoid as well as a purge solenoid so when its operating it allows fresh air in the tank and draws the fuel vapors into the engine.
Boosted applications need to install a one way check valve or they can pressurize the fuel tank.
If you were going to eliminate the evap completely you will have to add the vent to the tank and install a restriction in the vacuum line from the manifold to the evap line to limit the amount of a vacuum leak you are creating and also limit the amount of fuel vapors you are pulling from the tank.
You can remove everything. the tank will vent through the big hose coming off of the top of the tank(black fitting i think). you may have some vapor smell but its a racecar and you said your not worried about that. The tank will not collapse without the evap system operating. Under most conditions the system is not even putting a vacc on the tank. The system is normally vented without command from the ecm (purge valve closed and vent valve open without power or ground). The canister just cuts down the vapors.
The following users liked this post:
Pbarby (02-05-2023)
I assume you have codes set then. The good thing is when there is a system fault it wont keep trying to operate the system so it just vents all the time out of the vent valve after the vapors pass through the canister. You really dont even need a filter. just block it off or remove all the evap stuff under the hood (lines and purge valve).
The easiest way to do it for a race car is to plug off everything and modify the fill cap to vent this way the vapors are not trapped under the car.
Didnt see it was for a race car in the OP post but the stock system is always sealed and only operates the vent when its purging the tank thats why the Pain in the *** P0442 code come into play when their is a leak in the system.
I didnt explain real well what i meant but yea you are right. I was just saying that when the car is off and/or the PCM is not commanding the vent solenoid valve the default vent valve position is open and venting. It vents through the canister before it releases to the atmosphere. Thats why you dont smell gas around your car when you walk around it ( unless your canister is saturated). i guess my point is if you disable the system with the tune then the tank will vent all the time out of the larger hose off the top of the tank that goes into the canister then vent out through the vent valve.
I assume when they say are removing the system completely that they are taking everything off the car (less weight also) and usually the first thing people do is reach for the rubber block offs and plug everything up usually causing more problems than helping.
Completely seal a tank and it will make its own vent very soon usually scare the hell out of them too .
artls1@comcast.net
