99+ Trap door dimensions
Old 07-15-2007, 09:21 AM
The SSheriff's Avatar
Default 99+ Trap door dimensions
Hey everyone,
I have a 99 Camaro and am going to be cutting into the car today. I was just wondering what the dimensions are for the trap door. Pics would be helpful, but numbers alone are OK.
Old 07-15-2007, 09:57 AM
2002ws-6's Avatar
Here are some pics
Old 07-15-2007, 10:00 AM
2002ws-6's Avatar
I used a dremel with the flex cable extention each 1.5" disc cut one of the four sides. I cut the right side first then started the top. Once the top was open a little I slid a peice of sheet metal under the part I was cutting but above the wires and hoses so that It would be impossible to cut anything I didn't want to.
Old 07-15-2007, 11:13 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I cut the whole center section out:
Old 07-15-2007, 12:07 PM
BlkHwk's Avatar
I used a 6" holesaw from Home Depot, about 25 bucks if I remember correctly. Then used a cutoff wheel to trim for better access to the quick connect fittings.
Full Tank of Fuel
Old 07-15-2007, 03:03 PM
Thanks everyone. Cutting into the car now!!
Old 10-31-2008, 07:02 AM
joblo1978's Avatar
Nice!
Old 03-06-2009, 01:23 PM
ping2day's Avatar
saving for pump replacement
Old 03-09-2009, 03:31 AM
nemss1's Avatar
exactly what i did to remove the damn charcoal canister when i deleted my EVAP system
also came in handy when my fuel pump died
Old 04-02-2010, 08:28 AM
badmfkr's Avatar
Default special tool for removing fuel pump lines on top of tank?
Originally Posted by 2002ws-6
Here are some pics
very helpfull infor. here. nice job on the trap door ? I'm assumming from all the images I've sean that you're car is a 99+?
if yes to 99+ wound you please share the dimensions of the hole.
I have removed fuel line from my fuel fliter used needle nose pliers I bought a sissors type tool however cound'nt get it to work.
I have also removed the fuel line from the fuel rail this time I bought a round tool which slide over the line it came in a package of about 8 sizes.
? I have never removed fuel lines on top of the fuel pump
is there a special tool for removing fuel pump lines on top of tank?
I'm planning a trap door for future fuel pump install and want to be prepared.
I searched for 2 hours
Thanks
Quick Reply: 99+ Trap door dimensions
