What injectors for TREX cam.
i have the stock injectors in my ws6 with a cam only with around 430rwhp.. i plan on runnin 100shot soon.
i was told just to go with the stock 03 z06 injectors b/c i found some for 50 bucks. i belive they are 28lbs? would this be good?
You only need bigger injectors if your nitrous is a dry shot. If you wanted to be totally safe you could upgrade to 42# injectors but you will need a new tune. My stock 28.8# injecors were good to 450rwhp.
I believe the 03 ZO6 injectors are 28.8# the same as 01-02 F-bodys. They are slightly bigger than your stock injectors which are 26#. If you are not running a dry nitrous shot they will be fine. Otherwise I would use 42# injectors so you have room to grow.
Originally Posted by LightEmUpLs1
so these stock 03 zo6 injectors..... are 50 bucks. wat size are they?
and is this wat i sho uld go with?
[QUOTE=LightEmUpLs1]i have the stock injectors in my ws6 with a cam only with around 430rwhp.. i plan on runnin 100shot soon.
Man, you made 430 with a Trex only? Thats awsome!!!
should be a good read for you 98Camarod
https://ls1tech.com/forums/generation-iii-internal-engine/683617-do-any-shops-market-small-cams-anymore-why-not.html
when cartek tuned my cam only (22x/22x) ss, they put 30# (svo redtop) injectors in my car after the first pull be cause the car maxed out the stock injectors. after we put the 30's in with the new tune it drove like a dream.
