Belt driven fuel pump
#164
so im experiencing cold start issues after the car has been sitting for awhile, it seems as if the pump wont prime. im running a sumped stock tank and the pump is just a little below the level of the tank. would using one of the holley inline pumps to push the fuel to the belt drive pump cause a restriction or have any negative effect?
it is a return style system with a -10 supply and -8 return. just doesn't want to start after its been sitting for awhile.
#165
#171
http://www.jegs.com/i/Moroso/710/238...oductId=745635
I think aeromotive makes one as well.
#172
you just have to turn the diameter on the back down a little smaller to fit into the ATI balancer.
#179
This thread was very informative for me so i thought i should share my set-up for anyone else doing their homework.
The Mighty Mouse bracket i picked up was the one for use with the Aeromotive bracket that came with the pump.
Only problem now is that i'm considering going 100% Methanol so i'm hoping this pump will support up to 1500hp
Here are the pics of it mocked up everything fits perfectly:
[/URL]
[/URL]
[/URL]
Here it is with the Mighty Mouse bracket:
[/URL]
And just for the heck of it here it is with the AEI motor plate mocked up:
[/URL]
[/URL]
[/URL]
[/URL]
