Boost referenced Fuel Pressure Regulator
Hi,
What is this? What is pros and cons? Where can I get it? How much? Any how to ?
Thanks in advance!!!
-Mike
***BTW, I got Mototrons 60lbs injectors
-Mike
Originally Posted by MikeC5Vert
Hi,
-Mike
-Mike
I run the Aeromotive Universal FPR that's boost referenced. Pro's ==== it will 1 psi of fuel per 1 psi of boost hence why it's boost referenced. You can buy them at Jegs, Summit, and just about anywhere else.
I can't think of any con's .......
Cheers,
Tim
Thanks so much Tim!!!
Is it really hard to install to a stock system?
Thanks,
-Mike
Thanks,
-Mike
I'm not so sure about the specs on a stock LS1 system, however, there is no reason why you could not make it work. Typically with the FPR you'll have to hook the vacuum up to it and then hook up the fuel line. I'm sure you could make it work but not exaclty sure how. Sorry but my knowledge of LS1 fuel systems is very limited.
BTW, I recommended the Aeromotive Universal because I've found it to be an outstanding unit, although, I'm sure there are lots of others and maybe a fellow LS1 owner will jump in here and recommend something that will fit in with your stock fuel system better?
Regards,
Tim
Thanks for chiming in..... I said right away that I wasn't sure but that the aeromotive is a good unit. I appreciate you helping out.
I figured it was like my fuel system and you must have aftermarket rails and/or fuel lines, however, wasn't 100% sure and didn't want to just proliferate bogus info.
Thanks!!!!!
Thanks!!!!!
Thanks y'all ... look like I either need the whole new fuel system or just need to change the tuning file.
I got the tune file from another member with got identical setup but his IFR table's consistant thru out the RPM so I plan to add FPR.
-Mike
-Mike
I used the 97-98 c5 fuel rails which has a return on it. Also im running a breathless performance 1:1 regulator. I used my purge line as the return to the tank and removed the in tank regulator. Thats a very easy and cheap way to a 600rwhp setup with a good pump in tank.
-Mike
also interested in more info about that purge line. Decent rails arent too expensive.
If im correct this is how it works?:
-pull tank and chuck regulator thats inside?
-hook VAFPR in-line with feed and give vac source
-run a new line from return on fuel rail to the tank
I wonder how a walbro 255 would do with proper inj, rails, ect
You don't have to replace the fuel rails if you don't want to. You could get a remote FPR, I assume theyhave these in boost referenced models. They would have a pressure input, a return output and a pressure regulated output going to the rail.
Re'
Re'
any link/info to these remote FPRs?
Also:
-does the stock regulator need to be plugged where it once was?
-is the return line basically just a stainless line running from the quick connect in front of the rear axle to the tank (not actually a full new line all the way up to the rails, correct?)
is this pic correct:
Also:
[QUOTE=JAvenger007]any link/info to these remote FPRs?
Also:
Bump up because I want to know what to do about unplugging the stock regulator. I am in the same boat.
As for return lines guys, I am using a return line from a 3.8 V6 firebird. They have a normal return line that hooks up to the 97 vette rail and runs all the way back to the quick connect on the regular V8 systems. I thought GM would charge a lot for the fuel lines, but they were only $45.
Also:
I'm using the 97-98 rails as well, I just ran a new return line rather than using the EVAP as a return. The new return line starts at the "T" in the hard line near the rear axle.
So is this breathless performance regulator available on their site? The one they have doesn't say its 1:1
8 sec potential, 12 sec slip
Originally Posted by JAvenger007
...-is the return line basically just a stainless line running from the quick connect in front of the rear axle to the tank (not actually a full new line all the way up to the rails, correct?)
So you made a new line running from the front and it connects into the "T" at the back?
I also used a adjustable fuel pressure reg on stock 97-98 vette rails. I have yet to determine how it acts under boost. I don't believe its 1:1 referenced, but it is working, I'm making 570rwhp on Corn, which requires more fuel
