Peace of Mind: 9 inch?
Well I decided that I want to put a rear end in my car, after my h/c installi should be around 440hp which is death to a 10 bolt in a M6. So i've decided I want to get a 9 inch, my question is this, should i build one or just buy one outright? Building one seems about 500-600 bucks cheaper, may not be as strong but I wont be pushing more than 600hp with nitrous. So should I build one or just spend the 2400 out right and buy one new?
http://www.exoticperformanceplus.com....html?item=145 Bob
It could be a bit cheaper to build it yourself but look at your total cost. You may need Asjustable LCAs, Panhard bar, Torque arm, driveshaft ect.
I went with Midwest Chassis, Eric gives killer discounts on his parts and also on things like driveshafts when you order his fabbed 9", and his rear also includeds a torque arm.
Just depends on what you want to do. Either EPP or Midwest chassis will give you great service though.
Another way that is a great way to go is with the Moser M9. Here is a video about it.
http://www.exoticperformanceplus.com...html?item=1355
Link to the Moser M9 that I sell. Bob
http://www.exoticperformanceplus.com...html?item=1324
It isn't, the basic package does not include the center section. The center section is one of the options. I should redo it to where it comes standard with the Truetrac, then offer locker and spool upgrades. Actually a spool is less money, but if I start it with a spool, some people may not catch that and order it from my website with a spool when they don't want a spool. Bob
Moser M9 Bolt In F Body Housing/Axle/Torque Arm Package - Pick your center section from the options list
Bob
